Kevin78613's avatar
Kevin78613
Wired and wireless backhaul
Need to check if this will work. I have the router and a satellite working in the house using wireless. The guest house is 200 feet away and the walls are all stone do wifi does not reach. We are planning to run a CAT6 line to the guest house from the ORBI router to the second satellite. Basically running a wireless backchannel in the house and a wired one to the guest house. Will that work?
  • CrimpOn's avatar
    CrimpOn
    Jul 07, 2020
    There have been numerous reports of "mixed" satellite connections.  The "good news" is that satellite connection is monitored constantly and if the ethernet connection suddenly goes away, the satellite will go back to WiFi backhaul.  And, if the 5G backhaul has a bad enough connection, it will turn to a 2.4G WiFi backhaul.
    Fortunately, this is an easy thing to test. Put both satellites in the same room with the router and let them sync over WiFi.  Connect one with an ethernet patch cable and in a few minutes it will switch to ethernet backhaul.  (I do not remember how many minutes it takes for the switch.)
    • CrimpOn's avatar
      CrimpOn
      I like that web page except I wish Netgear had put a statement somewhere on the page to say, "There can be a MIX of some satellites with wireless backhaul and some with ethernet backhaul."  Better yet, a picture showing the mix.
    • Kevin78613's avatar
      Kevin78613
      Thank you for the reply. However the webpage shows all satellites being wired to the router. My question can one be wireless to the router and one being hardwired to the router. The illustration does not show that or indicate that it can be done. Wireless on one and wired on the other is my situation.
      • CrimpOn's avatar
        CrimpOn
