Shimmyhill
Sep 30, 2018Aspirant
Wired back haul better?
I have a Orbi RBR40 setup that replaced a Nighthawk router a while back, the WiFi is much better across our bungalow but we have been getting dropouts and I think it’s the satellite dropping - should...
Shimmyhill
Oct 16, 2018Aspirant
I have had a play around and now only have one Sonos wired as needed, all others are wireless and now the Orbi units and direct to devices or the switch so not using the Sonos or Home plugs as hubs, revised map attached!
ekhalil
Oct 16, 2018Master
Great. I hope this setup will work better now. Good luck!
