ronothan
Jul 19, 2019Tutor
Wired Backhaul - RBR40 vs RBR50
Does having an ethernet backhaul mean that you could get away with a RBR20 or RBR40 setup, and have the same awesomeness of the RB50 devices? I'm managing a building with 10 serviced serviced ap...
- Jul 19, 2019
The "50" devices have more powerful radios than the "40" devices, and thus will provide a stronger signal over a greater area. As long as satellites are wired to the router, backhaul speed is not an issue. It depends on where you want to mount satellites in relation to the apartments (where occupants can get at them? in closets? in the ceiling?) And, how large the apartments are.
ronothan
Jul 20, 2019Tutor
It’s a block of 10 apartments that are airbnb’s. People are only there for a few days or a week. I hear your point. I could put different routers in each apartment with different SSID’s and force network isolation to ensure each router is private but Orbi will provide more coverage, albeit with a little less security.
The only thing I may consider doing is having two seperate networks, using the Guest Wifi as I work from here and will need my NAS, security cameras etc to be on a different network.
