heathweather
Aug 22, 2019Guide
Wired backhaul configured but still shows WLAN Backhaul Statistics
I've got an RBR-50 (configured as an AP) with satellites configured using wired ethernet backhaul. The GUI shows all the satellites connected using wired backhaul. When I go to advanced -> admin...
Aug 22, 2019Guru - Experienced User
Are RBS directly connected to the RBR or thru a LAN switch?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
Let us know if disabling Daisy Chain does anything differently for you.
heathweather wrote:I've got an RBR-50 (configured as an AP) with satellites configured using wired ethernet backhaul. The GUI shows all the satellites connected using wired backhaul.
When I go to advanced -> administration -> router stats , there's still a significant amount of traffic being reported over the WLAN backhaul ?
With everything being configured as wired for the backhaul, these numbers should not be incrementing?
- heathweatherAug 22, 2019Guide
Firmware: 2.3.5.30
Both RBS connected through tplink TL-SG1024DE ( it is a managed switch, I've got IGMP snooping disabled )
I do not have daisychain enabled.
Thanks for your reply.
- FURRYe38Aug 22, 2019Guru - Experienced User
What is the status if you connect one of the RBS or both as a quick test directly to the RBR with out the switch in the middle?
One other factor of the switch that may be a cause, your switch seems to have Green Ethernet features: "Innovative energy-efficient technology reduces power output by up to 18%" Something that also causes Orbi to not work well. :smileyfrustrated:
Trying it now - will post the results.
