heathweather
Aug 22, 2019Guide
Wired backhaul configured but still shows WLAN Backhaul Statistics
I've got an RBR-50 (configured as an AP) with satellites configured using wired ethernet backhaul. The GUI shows all the satellites connected using wired backhaul. When I go to advanced -> admin...
heathweather
Aug 22, 2019Guide
The "enable daisychain topology" is not ticked. That was a lesson learned in getting the ethernet backhaul to work. Thank you for the reply.
Aug 22, 2019Guru - Experienced User
Are RBS directly connected to the RBR or thru a LAN switch?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
