heathweather
Aug 22, 2019Guide
Wired backhaul configured but still shows WLAN Backhaul Statistics
I've got an RBR-50 (configured as an AP) with satellites configured using wired ethernet backhaul. The GUI shows all the satellites connected using wired backhaul. When I go to advanced -> admin...
Aug 22, 2019Guru - Experienced User
What is the status if you connect one of the RBS or both as a quick test directly to the RBR with out the switch in the middle?
One other factor of the switch that may be a cause, your switch seems to have Green Ethernet features: "Innovative energy-efficient technology reduces power output by up to 18%" Something that also causes Orbi to not work well. :smileyfrustrated:
heathweather
Aug 22, 2019Guide
Trying it now - will post the results.
- heathweatherAug 22, 2019Guide
Current config - RBR50 (AP) with one RBS50 directly cabled
Interesting - there doesn't appear to be any backhaul traffic, outside of what appears to be a beacon of 59 packets transmitted every five seconds.
I'm going to attach the second RBS50 through the tplink and see what we get.
- FURRYe38Aug 22, 2019Guru - Experienced User
So did the one RBS directly connected to the back of the RBR show wired or wireless as the status?
The directly cabled RBS showed wired.
Then I connected another satellite through the switch, and it too showed wired, but then backhaul traffic started.
I've got two satellites hooked up now, directly attached, and after a little activity on the wireless backhaul, it has gone quiet.
My next trial will be connecting an 8 port unmanaged gigabit switch to the RBR50, then the satellites to the 8 port switch, and see how that goes.
