heathweather
Aug 22, 2019Guide
Wired backhaul configured but still shows WLAN Backhaul Statistics
I've got an RBR-50 (configured as an AP) with satellites configured using wired ethernet backhaul. The GUI shows all the satellites connected using wired backhaul. When I go to advanced -> admin...
heathweather
Aug 22, 2019Guide
Trying it now - will post the results.
heathweather
Aug 22, 2019Guide
Current config - RBR50 (AP) with one RBS50 directly cabled
Interesting - there doesn't appear to be any backhaul traffic, outside of what appears to be a beacon of 59 packets transmitted every five seconds.
I'm going to attach the second RBS50 through the tplink and see what we get.
- FURRYe38Aug 22, 2019Guru - Experienced User
So did the one RBS directly connected to the back of the RBR show wired or wireless as the status?
- heathweatherAug 22, 2019Guide
The directly cabled RBS showed wired.
Then I connected another satellite through the switch, and it too showed wired, but then backhaul traffic started.
I've got two satellites hooked up now, directly attached, and after a little activity on the wireless backhaul, it has gone quiet.
My next trial will be connecting an 8 port unmanaged gigabit switch to the RBR50, then the satellites to the 8 port switch, and see how that goes.
Let us know....whats the Mfr and model# of the unmanged switch?
Possible that your managed switch, even though had IGMP disabled, the green ethernet features maybe playing a roll in the bad behavior seen on Orbi.
- HTBruceMAug 22, 2019Guide
This post caught my attention. I've got wired backhaul from an RBR50 to (2) RBS50s. Direct connected - no intervening switch. I also see between 44-59 TX packets and 0-2 RX packets every 5 seconds on the WLAN Backhaul stats. Maybe some sort of minor housekeeping broadcast always running over WLAN backhaul?
I'm almost certain its a hardware watchdog of sorts, polling continuously. My RxPkts has not increased at all, while the TxPkts increases by no more than 59 every five seconds.
