ekhalil
Jul 28, 2019Master
Wired Backhaul in recent firmware releases
It seems that the wired backhaul design has changed in recent formware releases. It was a "known fact" that if you want to setup wired backhaul for a certain Satellite that you need to first sync th...
ekhalil
Jul 28, 2019Master
FURRYe38 wrote:........ Once it was wireless and wire connected, I saved the IP address, turned off the RBS and placed it at it's remote location. ......
If in the "remote location" the RBS will not see the backhaul radio from the RBR then I think no loops will be generated and you will not see the issue.
Jul 28, 2019Guru - Experienced User
Possible. The remote location changed from the main level to downstairs in the basement. This remote location is still wired and running thru 4x Gb non managed switches.
