ekhalil
Jul 28, 2019Master
Wired Backhaul in recent firmware releases
It seems that the wired backhaul design has changed in recent formware releases. It was a "known fact" that if you want to setup wired backhaul for a certain Satellite that you need to first sync th...
ekhalil
Aug 01, 2019Master
FURRYe38 wrote:.......
However it was listed as a Connected Device in the list below and Connection type said wired. I was able to access the RBS's web page at this address.
Is the Satellite still showing as a connected device, or did it change by itself to Satellite in the top of the Attached Devices list?
Aug 01, 2019Guru - Experienced User
The initial setup shows as a connected device. The RBS didn't appear in the connected satellites section at all. It's been a few days now, I'll check the status when I get home today.
- FURRYe38Aug 01, 2019Guru - Experienced User
The RBS is not showing for a "Connected Satellite".
It does still appears in the Connected Clients list:
NETGEAR --- 192.168.0.103 MAC ADDR Wired
I presume that the Connected Satellite status may depend upon first connection with RBS via wireless, then once thats established, wired connection would appear correctly when that was connected.
- ekhalilAug 01, 2019Master
No, I did not do any wireless sync between Satellite and Router. I only synced them once when they were wired, and I see the Satellite as Satellite in the top of the Attached Devices list.
I would repeat the sync procedure again while the nodes are wired.
- FURRYe38Aug 02, 2019Guru - Experienced User
I'll try again. All I did was turn ON the RBS while the LAN cable was connected and let it sync on it's own. I'll power it OFF and reboot the RBR. Possible process maybe different while the RBR is in AP mode.
