ekhalil
Jul 28, 2019Master
Wired Backhaul in recent firmware releases
It seems that the wired backhaul design has changed in recent formware releases. It was a "known fact" that if you want to setup wired backhaul for a certain Satellite that you need to first sync th...
Aug 05, 2019Guru - Experienced User
Ok, finally on the 3rd try, I got the RBS to sync with LAN cable connected and it's configured for the right SSID name.
I did a factory reset while the RBS was wirelessly connected. Then powered it off. Plugged in the LAN cable. Waited for the top led to pulsate WHITE, it the sync button for 5 seconds, then hit the sync button on the RBR in the web page. Got BLUE led with in about 30 seconds and it shows up in the RBRs UI as a connected satellite with a WIred status.
1 Netgear Orbi Satellite-1 192.168.0.103 192.168.0.103 MAC Wired Orbi Router
MAC Good
ekhalil
Aug 05, 2019Master
True, the Satellite’s own SSID (ORBIxx) will take some time to disappear. Just leave it, once the ”Config Sync” is successfully completed the Satellite will be updated -after being wiped- by the Router and the Satellite will get the main SSID. This can take few minutes to happen.
