tmrbrts
Dec 15, 2020Aspirant
Wired backhaul inconsistencies and switch problems
Firstly, apologies for the long post! I bought an RBK23 system with router and two satellites a few months ago, primarily to provide good wifi in our garden office, via wired backhaul. Set up we...
- Dec 16, 2020
Try the HP ProCurve 1400/1800 series.
Thes switches mentioned I have tested and I have seen no issues with orbi systems. Some of the newer Rev versions of the NG or D-Link switch have EEE and I believe some of the older versions may not. Though be aware that Orbi 50 series v16 FW is last working version of FW that works with RBS ethernet connected with switches. All other FW versions after v16 causes an ARP storm for unknown reasons. So I don't recommend any version of FW after v16 until NG fixes what ever is causing these ARP storms in later FW versions.
tmrbrts wrote:
Thanks for the reply.
Firmware was the same on both RBS and RBR: v.2.5.1.26.
Syncing on the RBK50 worked fine in the house, first wirelessly and then via temporary ethernet cable in the same room. But when moved to the garden office it would only connect wirelessly (same with the Asus). I just don't get it, when the RBK23 works every time I plug it back in.
Anyway, given that the RBK23 works ok at the moment on wired backhaul, I think my focus needs to be on finding a switch that works.
I note that the D-Link switches support EEE, so are the switches you mentioned all ones that are known to work *despite* supporting EEE? If so, it looks like I need to invest in one. Are there any switches which don't support EEE?
Thanks.
Dec 15, 2020Guru - Experienced User
RBS and RBR should be same version for each model series.
First thing to try is to bring the RBS to near or same room as the RBR. First wirelessly sync it to the RBR. After it's fully sync wirelessly, then connect up a temp LAN cable between the RBR and RBS to be sure it's syncing correctly.
Be sure you are connecting the RBS behind the RBR:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
tmrbrts
Dec 16, 2020Aspirant
Thanks.
Thanks.
- FURRYe38Dec 16, 2020Guru - Experienced User
Thanks.
