datascope11
Sep 03, 2019Aspirant
Wired Backhaul Issues
Hello all. I've had an Orbi RBK50 with 1 satelitte in my home for years now. It works quite well, except during/after firmware updates where more things get broken than fixed... Anyhow - I recently i...
heathweather
Sep 04, 2019Guide
Just for a sanity check, directly connect the satellite to the orbi router with a short Cat5e or 6 cable and see if it will show up as wired. If it does, you might have a cable issue with the one that runs in the vent.
Is it configured as an access point or in router mode?
