darrenkdean
Jun 12, 2018Tutor
Wired Backhaul Not Reconnecting After Power Outage?
Have been using the Orbi system with three satellites for some time now (successfully). The Orbi Router & two of the satellites (running in AP Mode) are hard wired to a Cisco Switch & configured to ...
Jul 02, 2018Guru - Experienced User
Your issue maybe your managed swtich. Others have had problems with managed switches and IGMP protocols.
Try testing the with non managed switch in place.
darrenkdean
Jul 03, 2018Tutor
IGMP snooping protocols are not enabled on the switch; never have been. The managed Cisco switch is not the issue, it's Netgear Orbi Firmware.
After messing around with it for two hours & failing to bring the wired backhaul back up, I downgraded the firmware back to 2.1.4.10. The wired backhaul instantly came back up. Very frustrating.
When the Orbi's are up & running they run beautifully. Netgear has some work to do when it comes to power outages / reboots / firmware.
Best-
Darren
- FURRYe38Jul 03, 2018Guru - Experienced User
Something you can contact them and ask about and let them know.
Good Luck.
