budy
Jan 27, 2018Luminary
Wired backhaul on 2.1.2.18 magenta LED but correct device assignments
Up to now, I always used the ethernet wired backhaul with the router port on my router, which runs in AP mode. This worked very well, but hat the issue, that wireless devices on the satellite were sh...
Apr 24, 2018Guru - Experienced User
Wired back haul was flakey in v2.1.x.x, works well in v2.1.3.4. A factory reset is needed here then set up from scratch.
Be advised there is newer v2.1.4.10 FW now for 50 series systems:
https://kb.netgear.com/000055985/RBR50-RBS50-Firmware-Version-2-1-4-10
Up to you if you wanna try it.
