tjochem
Aug 21, 2020Aspirant
Wired Backhaul Problems with RBR50/RBS50
Hi, I'm at wits end. To support some virtual schooling, I reconfigured our orbi setup. RBR50 is in AP mode. 2 Satellites. Because the one satellite is in an addition, behind a brick wall, I wanted t...
- Aug 21, 2020
If CAT5, or possible bad cable could cause some problems if not working well.
What is the Mfr and model # of this switch?
Try this, turn OFF the one wireless RBS and leave the wired RBS connected. Does the problem still happen?
Aug 21, 2020Guru - Experienced User
Is the RBS directly connected to the RBR or is there a ethernet switch in between?
IF there is a switch what is the Mfr and model # of this switch?
What catgory LAN cable are you using? CAT6 is minimum recommended.
Has a factory reset and setup from scratch been performed since last update?
- tjochemAug 21, 2020Aspirant
Is the RBS directly connected to the RBR or is there a ethernet switch in between? Yes. And I tried it both ways and same result. (Its an unmanaged switch)
What catgory LAN cable are you using? CAT6 is minimum recommended.? I do not think it is. I'm a little skeptical that the cable could bring down the network though.
Has a factory reset and setup from scratch been performed since last update? Yes, on RBR and RBS'
- FURRYe38Aug 21, 2020Guru - Experienced User
OK. I will get this info and post back.
