tjochem's avatar
tjochem
Wired Backhaul Problems with RBR50/RBS50
Hi, I'm at wits end. To support some virtual schooling, I reconfigured our orbi setup. RBR50 is in AP mode. 2 Satellites. Because the one satellite is in an addition, behind a brick wall, I wanted t...
  • FURRYe38's avatar
    If CAT5, or possible bad cable could cause some problems if not working well.
    What is the Mfr and model # of this switch?
    Try this, turn OFF the one wireless RBS and leave the wired RBS connected. Does the problem still happen?
