tjochem
Aug 21, 2020Aspirant
Wired Backhaul Problems with RBR50/RBS50
Hi, I'm at wits end. To support some virtual schooling, I reconfigured our orbi setup. RBR50 is in AP mode. 2 Satellites. Because the one satellite is in an addition, behind a brick wall, I wanted t...
- Aug 21, 2020
If CAT5, or possible bad cable could cause some problems if not working well.
What is the Mfr and model # of this switch?
Try this, turn OFF the one wireless RBS and leave the wired RBS connected. Does the problem still happen?
tjochem
Is the RBS directly connected to the RBR or is there a ethernet switch in between? Yes. And I tried it both ways and same result. (Its an unmanaged switch)
What catgory LAN cable are you using? CAT6 is minimum recommended.? I do not think it is. I'm a little skeptical that the cable could bring down the network though.
Has a factory reset and setup from scratch been performed since last update? Yes, on RBR and RBS'
Aug 21, 2020Guru - Experienced User
