docgravel
Feb 19, 2021Aspirant
Wired backhaul with RBK50 and RBS50 disabling ethernet ports in satellite
I have been trying to configure Wired Backhaul with my RBK50 and RBS50. I have 2 RBS50s, but I've turned one off to try to isolate the problem. I have a MoCA (GoCoax) adapter set up to connect the wi...
- Feb 26, 2021I think I figured it out! It was unrelated to my Orbi and totally related to the GoCoax MoCA adapters. I was able to reproduce this issue with RBK -> GoCoax -> GoCoax -> Switch -> 2 or more devices. They all had the same static IP address by default, which appears to not be a problem if you're using them to connect one device on the other end, but as soon as you connect them to a router or a switch with multiple devices, it looks like this was causing problems. I didn't even realize these devices had IP addresses because they were on a different subnet and were static IPs. I just set them all to use DHCP with reserved addresses and the network has been stable for the last 2 hours with many devices connected to ethernet.
CrimpOn
Feb 19, 2021Guru - Experienced User
Yes, of course, ethernet ports on the RBR50 and RBS50 should remain usable when the sattelite is using ethernet backhaul.
The only MoCA connections are to the router and satellite, correct? (aside from TV sets)
I always assign IP addresses to devices which are "permanent", such as Orbi satellites, printers, IP cameras, etc.
(I do not see this as relevant to the problem, but it is a common practice.)
docgravel
Feb 26, 2021Aspirant
- CrimpOnFeb 26, 2021Guru - Experienced User
Thanks for the solution. My TP-Link Powerline units have no IP address. Since the electrical circuit is essentially one "local area", they must use some sort of Powerline broadcast to find each other. When I start the TP-Link's Powerline management program, the units just "pop up" on the screen.
