docgravel
Feb 19, 2021Aspirant
Wired backhaul with RBK50 and RBS50 disabling ethernet ports in satellite
I have been trying to configure Wired Backhaul with my RBK50 and RBS50. I have 2 RBS50s, but I've turned one off to try to isolate the problem. I have a MoCA (GoCoax) adapter set up to connect the wi...
- Feb 26, 2021I think I figured it out! It was unrelated to my Orbi and totally related to the GoCoax MoCA adapters. I was able to reproduce this issue with RBK -> GoCoax -> GoCoax -> Switch -> 2 or more devices. They all had the same static IP address by default, which appears to not be a problem if you're using them to connect one device on the other end, but as soon as you connect them to a router or a switch with multiple devices, it looks like this was causing problems. I didn't even realize these devices had IP addresses because they were on a different subnet and were static IPs. I just set them all to use DHCP with reserved addresses and the network has been stable for the last 2 hours with many devices connected to ethernet.
docgravel
Feb 26, 2021Aspirant
CrimpOn
Feb 26, 2021Guru - Experienced User
Thanks for the solution. My TP-Link Powerline units have no IP address. Since the electrical circuit is essentially one "local area", they must use some sort of Powerline broadcast to find each other. When I start the TP-Link's Powerline management program, the units just "pop up" on the screen.
