nick776
Feb 11, 2017Guide
Wired Backhaul
My refund period for my Orbi is about to expire. Can a moderator comment (hopefully a NetGear Employee) as to when/if we will get wired backhaul? If it is in the next six months, I will keep my Orb...
- Feb 23, 2017
Nick,
Here's something I posted this morning on another thread for the same topic:
I've added Ethernet Backhaul into my list of Candidate Features for a future Firmware update. I can't yet commit to a delivery date, but wanted to acknowledge that this is a valid use case and something we're looking seriously at.
Orbi Product Management
st_shaw
Apr 16, 2017Master
schumaku wrote:
st_shaw wrote:
... my 2011 MacBook Pro connects to Orbi 5 GHz at 300 Mbps, but I have a brand new WiFi modem from CenturyLink and a Ubiquiti AP-AC-Pro, and the MacBook connects to both of these at 450 Mbps. The CenturyLink modem specs indicate it's 4x4 on 5 GHz.
The current Orbi systems have a dedicated 4x4 5 GHz radio backhaul, the client access is implemented by dedicated 2*2 on 5 GHz plus 2x2 on 2.4 GHz radios. While this won't allow max out the single user, single client throughput, it makes a nicely balanced solution for concurrent usage of multiple clients on multiple Orbi stations (router and satellites).
Ok. So does this mean the maximum connection speeds for Orbi are:
1. 866 for 802.11ac clients (two 433 Mbs streams)
2. 300 mpbs for 802.11n clients (two 150 Mbps streams)
schumaku
Apr 16, 2017Guru - Experienced User
st_shaw wrote:
So does this mean the maximum connection speeds for Orbi are: ...
For the Orbi router/AP, and for each Orbi satellite/AP. As such, Orbi does not want to compete with the single client best speed stuff. In y opinion, this is not a big issue - as the majority of mobile clients are 2x2 systems anyway - the newer Apple notebooks are an exception.
We should not go off-topic here.
