Technarf71
Jun 11, 2020Aspirant
Wired Bandwidth issue on yellow port
Hi everyone. For the story, I had a RBK50 V1 but after the satelitte has died after a bit less than 1 year, I've had a RBK50 V2 as a replacement unit. The first one was buggy and was rebooting rando...
schumaku
Jun 11, 2020Guru - Experienced User
Can just guess: The RBR50 does use an (industry standard) QCA8075 switch with five PHY ports, one to the core, one for the WAN/Internet port, and three for the LAN port. Well possible, they don't reconfig the switch properly in AP mode, and continue using the WAN/Internet port (yellow marked) in a software bridge....
Technarf71
You're probably right... It would be better to have real gigabit on each port.... ;)
