SSuffolk
Apr 17, 2017Guide
Wired connection speed slower than Wifi Speed
I just purchased the Orbi Wifi system after having an ASUS AC5300 hoping to get better Wifi range which I did, but the problem is the wired connection download speed while performing a speedtest. I'm getting better results over Wifi than wired, why is this happening?
Wired:
Wireless:
Just tried again and it's working just fine, a mod can close this.
one of 2 things could be happening
ether the ethernet adapter in that device is only 100/10M or the ethernet cable is not right
i assume you plan speed is 100/40M
i assume you are in the states and are using the same server in NY for your tests
