Cylux
Mar 15, 2019Aspirant
Wired connection to satalite instead of router
Dear community, Can my wired speed be lower when I connect 3 wired devices to a wired satalite instead of the router? I am asking cause I don’t know if I want to pull 1 utp from the router to sata...
- Mar 15, 2019
Cylux wrote:
So it should not lower the quality/speed of my netwerk if I connect devices wired to a wired satalite instead of the devices wired to the router.You should not see lower quality if the cable between the Router and the Satellite has good quality. On the contrary you might get even better quality in this case if you will need shorter cables to the devices from the Satellite than what you would need from the Router.
Good luck!
Mar 15, 2019Guru - Experienced User
Yes you can.
You can also add on a non managed non green ethernet lan switch, ports 5 up to 48 if you like on the back of the RBR if you need additional LAN ports.
- CyluxMar 15, 2019AspirantThanks for your anwser.
So it should not lower the quality/speed of my netwerk if I connect devices wired to a wired satalite instead of the devices wired to the router.- ekhalilMar 15, 2019Master
Good luck!
