Geek95
Aug 22, 2016Follower
Wired Connection to Satellite
Is it possible to use Ethernet to connect router and satellites?
mdgm-ntgr
Aug 22, 2016NETGEAR Employee Retired
No, but this is a suggestion under consideration.
Part of the beauty of the Orbi solution is how it effectively connects the router to the satellites wirelessly. There is very good penetration.
dmystic1
Aug 23, 2016Apprentice
That would be a great feature and if it freed up the third 5ghz band for a true 3 band router with smart connect that would be even better.
