Geek95
Aug 22, 2016Follower
Wired Connection to Satellite
Is it possible to use Ethernet to connect router and satellites?
mdgm-ntgr
Aug 22, 2016NETGEAR Employee Retired
No, but this is a suggestion under consideration.
Part of the beauty of the Orbi solution is how it effectively connects the router to the satellites wirelessly. There is very good penetration.
seany187
Aug 24, 2016Star
I would also like this feature, especially since I currently have a second Nighthawk as my access point. I will be putting the Satellite in the same spot, seems silly not to hard-wire it.
