Geek95
Aug 22, 2016Follower
Wired Connection to Satellite
Is it possible to use Ethernet to connect router and satellites?
mdgm-ntgr
Aug 22, 2016NETGEAR Employee Retired
No, but this is a suggestion under consideration.
Part of the beauty of the Orbi solution is how it effectively connects the router to the satellites wirelessly. There is very good penetration.
alanfca
Aug 25, 2016Guide
I would like to request the ethernet backhaul feature option as welll. Would be nice feature for those of us with pre wired setups in the house. I believe that eero and luma do support the backhaul method of interconnectivity of mesh devices.
- seracSep 01, 2016Guide
eero does support hardwired "satelites" and luma has promissed to with first software update after launch
