Geek95
Aug 22, 2016Follower
Wired Connection to Satellite
Is it possible to use Ethernet to connect router and satellites?
mdgm-ntgr
Aug 22, 2016NETGEAR Employee Retired
No, but this is a suggestion under consideration.
Part of the beauty of the Orbi solution is how it effectively connects the router to the satellites wirelessly. There is very good penetration.
itGeeks
Sep 02, 2016Apprentice
There very well maybe good penatration however there still is a need for Eithernet backhaul in situation such as installing in a detached garage.
