Geek95
Aug 22, 2016Follower
Wired Connection to Satellite
Is it possible to use Ethernet to connect router and satellites?
st_shaw
Feb 13, 2017Master
Hirrdgoon wrote:
Finally, its pointless to have a 4 port switch on the back if not usuing the full ability of a wired network. Simply buying a switch and plugging devices into that would be a better idea.
Devices plugged into the 4-port switch can communicate with each other at full Gigabit Ethernet speeds. How is that pointless?
DublinB
Feb 13, 2017Initiate
Just getting back to point......
Has Orbi Netgear decided to allow an ethernet connection to their satelite box yet? Does anyone think this would be useful i.e. would it give a stronger signal from this satelite unit. Thank you for your responses
- Random12Feb 13, 2017Apprentice
I think a lot of folks in this forum would like to see this feature (myself included!). It would help with a variety of things. It may or may not help give you a "better" signal, there are so many factors involved, but there are clearly tons of scenarios where it can help. I think the main thing is this:
*Where* does it fall in Netgear's priority list? i.e. there are probably more important things (wireless stability issues, other important features, etc..). Personally, there a few higher priorities for them IMHO.
Regards
- SamirDFeb 13, 2017Prodigy
It is next to impossible to get internal schedules and priorities from companies on their products. If this system doesn't fully meet your needs, the space is getting new systems added every day that introduce a different mix of features that may meet your needs. The price ranges are all still about the same as well.
It is important to note that a lot of enterprise systems can be purchased for the same price of these 'high-end' consumer systems with much more robust design and implmentation. It does take a bit of learning and setup, but the benefits are a system that is designed to perform perfectly without fail--because that's what it does in business environments every day.
