DaveM1234
Nov 10, 2023Aspirant
Wired devices not routing: Orbi RBR50, RBS50
Hello,
My Orbi mesh system suddenly stopped routing wired devices. I had an RBR50 with two satellites (RBS50 and RBS20) previously working well. Suddenly my wired devices stopped routing.
Cur...
- Nov 10, 2023
I solved it. I am embarressed to say, I had a killswitch process running in the background. I had to go in through the CLI and kill the process then I got right through.
Thanks for all of the help.
DaveM1234
Hello,
Yes it's a desktop running Ubuntu 22.04.3 LTS
Ifconfig =
inet 192.168.3.4
netmask 255.255.255.0
broadcast 192.168.3.255
default route = 192.168.3.1
gateway = 192.168.3.1
arp -a
I can ping the
RBR50 3.1
RBS50 3.3
But I *cannot* ping 3.2 which is the laptop connected to the wifi router that I am typing on now.
From the laptop I *can* ping
The router, satellite, and the desktop that won't route out.
No changes to desktop except I did turn the firewall off for trouble shooting. Normal rule set to deny incoming and allow outgoing.
CrimpOn
Nov 10, 2023Guru - Experienced User
Thanks for the information. What sort of computer is the laptop?
(Windows, for example, does not respond to ICMP (ping) until told to do so. Here's one article - of many.)
https://www.en-zdv.uni-mainz.de/allowing-icmp-ping-in-the-windows-firewall/
Have you tried to ping something outside the local network, such as Google DNS (8.8.8.8)?
- DaveM1234Nov 10, 2023Aspirant
First, thank you for the assistance.
Laptop is Windows with McAffee Ultimate running.
Firewall is Windows Defender. I enabled ICMP Echo requests:
But still no luck.
From the wired connection, I cannot ping any outside address, the external wan interface on the RBR50, or any internet FQDN or IP such as 8.8.8.8.
Router settings are:
Connected devices:
Thanks again for the assist.
- CrimpOnNov 10, 2023Guru - Experienced User
Glad there was no issue with the Orbi. I was totally stumped.
