conanreidy
Jun 19, 2020Follower
wired ethernet router
I have a new cable modem CM1200 Nighthawk in my basement. Several ethernet cables also terminate in my basement. I also have an Orbi WiFi system in my house, currently connected via the 1 live port o...
Jun 19, 2020Guru - Experienced User
Seem like you would need a Gb LAN switch, not a rotuer, to connect your LAN ports and outlets to your Orbi system.
Check out NGs GS series of switches.
How many LAN outlets do you have in the home?
