DocZenith's avatar
DocZenith
Wired internet but no wireless
Hi,  I have been running the Orbi system with one satellite for X months now without any bigger problems. Since yesterday I cannot any longer use internet through wirelessly. Mobile phones, laptop...
  • DarrenM's avatar
    Feb 05, 2018
    I would try to do a full factory reset of the unit by holding the reset button for 10+ seconds then set the unit up again. Also make sure all the Orbi units are using the same firmware version.
    DarrenM
