DocZenith
Feb 02, 2018Aspirant
Wired internet but no wireless
Hi, I have been running the Orbi system with one satellite for X months now without any bigger problems. Since yesterday I cannot any longer use internet through wirelessly. Mobile phones, laptop...
- Feb 05, 2018
I would try to do a full factory reset of the unit by holding the reset button for 10+ seconds then set the unit up again. Also make sure all the Orbi units are using the same firmware version.
DarrenM
HBtechstuff
Feb 11, 2018Aspirant
I suspect there are deeper issues than a factory reset will solve. I have had my Orbis for roughly a year and each version of firmware seems to make things worse. My satellites lose connection to the router after what seems to be random lengths of time, I can never connect using 802.11ac even though my laptop supports 802.11ac and always connects using 802.11ac in my office. I find that if I connect an ethernet cable directly to the router I can get full throughput on my internet connection but even this drops to no more than 8 Mbps download after a few days. A reboot is the only way to return to my full 50 Mbps download speeds.
I have also started watching the WiFi signals from the satellites and router and have watched the satellites from transmitting different channels - specifically what looks like the backhaul channel.
Be happy to help provide data to get this resolved by frankly am about to replace these out of shear frustration.
DocWatson
Feb 12, 2018Tutor
wrote:I suspect there are deeper issues than a factory reset will solve. I have had my Orbis for roughly a year and each version of firmware seems to make things worse. My satellites lose connection to the router after what seems to be random lengths of time, I can never connect using 802.11ac even though my laptop supports 802.11ac and always connects using 802.11ac in my office. I find that if I connect an ethernet cable directly to the router I can get full throughput on my internet connection but even this drops to no more than 8 Mbps download after a few days. A reboot is the only way to return to my full 50 Mbps download speeds.
I share your frustration and I can't stay in this limbo status of servicability or lack of support for long either. I may need to move to another prodiuct and begin to move my clients to other products as well if we can't get this resolved. I don't think a product in this prrice point should have these many issues as well as such short support cycles. Let's see what response we get....
