geareason
Apr 07, 2020Aspirant
Wired IP Cameras connected to an Orbi Satellite in garage?
Is it possible to connect wired IP cameras (via powered switches) to an RBS50, and have that feed data through WIFI into the NVR which is wired to the RBK (or another satellite)? If so, I'd be ab...
tomschmidt
Apr 07, 2020Virtuoso
Orbi does not provide PoE output power on any ports. You can, however, connect a PoE-enabled switch to Orbi and power cameras that way.
