geareason
Apr 07, 2020Aspirant
Wired IP Cameras connected to an Orbi Satellite in garage?
Is it possible to connect wired IP cameras (via powered switches) to an RBS50, and have that feed data through WIFI into the NVR which is wired to the RBK (or another satellite)? If so, I'd be ab...
geareason
Good to know. I'm still researching gear right now but hopefully this is something it's able to do.
michaelkenward
Apr 08, 2020Guru - Experienced User
Good move. You are more likely to better answers if you provide details of the kit you have in mind. You may even find advice by running a search here for your brand options.
