lokimon
Jun 22, 2020Tutor
Wired Satellite Dropping Wired Connections
I have 2 Orbi Satellites Wired Directly to the Orbi Router. (Star Configuration) I have a couple of computers wired into one of the Satellites. Every 15-20 minutes, those computers lose their...
Jun 22, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
- lokimonJun 23, 2020Tutor
The Cable modem is a Arris Surfboard SB8200
There is no switch, the satelite wire runs through the wall into the basement and connects directly to the router.
3000 square foot house. The satellites are wire backhauled, not wirelessly connected.
This really isn't a wireless issue. The issue I'm having is with the wired computers.
Router -> Satellite -> Computer 1
-> Computer 2
All those connections are wired. If I take out the the satellite and connect directly to either computer, the issue of the computer losing connections goes away. If I put the satellite there, both computers lose the ability to ping the router every 15-20 minutes, but then it comes back after a couple of minutes.
