lokimon
Jun 22, 2020Tutor
Wired Satellite Dropping Wired Connections
I have 2 Orbi Satellites Wired Directly to the Orbi Router. (Star Configuration) I have a couple of computers wired into one of the Satellites. Every 15-20 minutes, those computers lose their...
CrimpOn
Jun 23, 2020Guru - Experienced User
lokimon wrote:Every 15-20 minutes, those computers lose their connection to the router.
I am no longer able to ping 192.168.1.1, until something resolves itself and it comes back.
I have no idea how to debug this. If I plug the wire going to the Satellite directly into one of the computers, I do not have this issue.
Are you running some sort of "Ping Plotter" program, or have a Command window open with a ping command running constantly?
Or, do you notice a "problem", then open a Command window and attempt to ping?
lokimon
Jun 23, 2020Tutor
No ping plotter, just running
ping -t 192.168.1.1
And watching the output. I will get lost packets every 15-20 minutes for a minute or so, before it comes back.
This does not occur when I take the satellite out of chain and connect directly to over if the computers.
ping -t 192.168.1.1
