bgibs2003
Jun 13, 2021Tutor
Wired Satellites
Hi - I have the RBR750 with two satellite setup. For each satellite, I have a wired ethernet connection. However, when I plug in the ethernet (to get the full speeds), they stop working uniformly. ...
- Jun 16, 2021
bgibs2003 wrote:Hi! Thank you so much for replying.
My setup is --> AT&T modem/router combo (but I have the router functionality turned off) --> the AT&T box has 4 drops on the back and is located in my smart home panel. From there, I have Ethernet cables patched to 3 outlets: one for the Base, and one for each Satellite. So, I'm using the AT&T box as a switch too.
It appears to me that you have configured the Orbi in a way that is not intended. The method Netgear intends is:
- The router WAN (Yellow) port is connected to the internet source. (modem or in this case a router)
- Orbi satellites are connected to the router over WiFi or over ethernet cables connected to the router LAN ports.
What you have done is connect the satellites to the Orbi through the WAN (Yellow) port so that both the internet and the satellites appear on the same router interface.
The problem is understandable. There is only one etherent cable running from the patch panel to each location. (why would anyone place two cables? Heck, my house has no patch panel at all and zero ethernet cables in the walls!) What you need is two ethernet cables from the patch panel to the router and to unplug the satellites from the AT&T switch and connect them to a separate switch. There was a great post recently showing how to use two switches to create a VLAN that allows both the WAN and LAN traffic to travel across a single ethernet cable:
https://community.netgear.com/t5/Orbi/Disabling-automatic-subnet-reconfig/m-p/2031354#M110164
172.16.0.x is a private IP address space. (as is 192.168.x.x) https://en.wikipedia.org/wiki/Private_network This indicates to me that the AT&T box is still acting as a router.
I think there are three choices:
- Leave the satellites in WiFi backhaul mode until you either
- Install another ethernet cable to the router location and put a small (dumb) switch at the patch panel, or
- Purchase two more capable switches and set up a VLAN like the previous user did.
CrimpOn
Jun 13, 2021Guru - Experienced User
It would help to have a diagram of the components and how they are connected, starting with the ISP modem (brand & model), and including any switches. For the Orbi to function correctly, all Orbi units must be in the same IP subnet, which is usually 192.168.1.x.
The typical connection pattern is:
ISP device --ethernet cable--> Orbi router WAN (yellow) port
then
Orbi router LAN port --ethernet--> satellite1 and
Orbi router LAN port--ethernet--> satellite2
Many people have ethernet wiring inside the walls that runs to a central patch panel and perhaps an ethernet switch. Because the patch panel is not in a good location for a WiFi access point, they often spread the Orbi units around the house and connect them all to a switch at the patch panel.
Please describe your setup.
alokeprasad
Jun 13, 2021Mentor
Pardon me for jumping in with a question (related to the topic title, of not to OP's situation):
- Is it required (or preferred?) that RBS's be connected directly to RBR's Ethernet ports?
- Is it OK to have one (or more) switches between RBR and RBS's?
There are just 3 usable ports on the RBS50. Ideally, I'll hang an 8 port switch on the RBR and connect it to Ethernet outlets around the house and attach switches on the other end of those outlets. Then attach wired devices or RBS's to those switches in those rooms.
That should be OK for fixed items like PC's, receivers, TV's in those rooms. Will it be OK to connect RBS's as well (with 2 switches between the RBS's and the RBR)?
- CrimpOnJun 13, 2021Guru - Experienced User
There have been numerous posts regarding how switches affect the router-satellite connection.
The general concensus appears to be that sometimes using a switch causes the link to be unstable.
A number of users have asked if there is a list of acceptable switches, and the answer appears to be "no".
The only way I know of to resolve the question is to give it a try and see what happens.
- bgibs2003Jun 16, 2021Tutor
Thanks for the reply!! What is the option if using switches causes it to be unreliable?
My main issue is that I can only use the family printer (WiFi) when the device I'm printing from is on the same AP as the printer (the main Router base).
CrimpOn wrote:There have been numerous posts regarding how switches affect the router-satellite connection.
