eehirsch's avatar
Dec 01, 2020
Wired speed significantly faster than WiFi
I have symmetrical 1gig fiber at my home, one Orbi RBR50v2 and two RBS50v2.  Backhaul is all wireless.  Latest firmware.  When connected to my satellites via ethernet I get about 600mbs up and down.  Via ethernet directly off the RBR50v2 I get about 1gig up and down.  Via wifi off the RBR or RBS I get about 400 down and 300 up no matter where I am in the house.  I have changed every setting imaginable, lowered power, moved or removed RBSs, etc.  One other data point - if I fully disable the Orbi system and shift to my ISP supplied router/modem (ATT BGW320) I get about 650mbs up and down via wifi within a reasonable range of the device (same floor or the floor above).  Wondering what's going on here and if things can be improved.  Thanks all.
  • FURRYe38's avatar
    Wired speeds will always be faster than wireless on Orbi.
    Most wifi devices max out at 400-500Mpbs on 5Ghz AC depending upon hardware design and support of the wireless device. Nature of the beast. Your getting good speeds on wireless especially through out your home.
