Thandungen
Jan 18, 2021Aspirant
Wired to Wireless data loss
Setup RBR50/Orbi AC300 + three RBS50 Satellites. Firmware: V2.7.2.102. We've just recently switched to Google Fiber with an average up/down of 950 Mbps wired. The average wireless speed throughou...
Jan 18, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
You'll not see anything near 900Mpbs on 5Ghz AC. Most devices max out at around 400-500Mbps depending upon there design and support. WIred speeds you should see near 900Mpbs. Orbi is cabable of that on the wire only.
- ThandungenJan 19, 2021Aspirant
Thank you very much! I'll try these and let you know how it goes. Appreciate it.
- FURRYe38Jan 19, 2021Guru - Experienced User
:smileywink:
