Jsonadam
Jul 24, 2020Tutor
Wired vs wireless backhaul with a 100mbps Ethernet
I have a 3 unit system RBR50 (router and two satellites). I also added an extra satellite (RBS20) fpr a totla of 4 units - 3 peiec RBR50 and extra satlellite. The router (obviously) is hard wired. O...
CrimpOn
Jul 25, 2020Guru - Experienced User
Jsonadam wrote:Would I be better keeping it as wireless backhaul or connecting to the 100 mbps ethernet?
Short of running extensive comparison throughput tests, there is no way to predict. You can get a rough idea of the current situation by connecting to the Orbi router with telnet and typing this command:
satelliteinfo wifi
Here's what my Orbi reports:
root@RBR50:/# satelliteinfo wifi
"mac address" : "A0:04:60:xx:xx:xx",
"hop" : "1",
"bridge mac" : "A0:04:60:xx:xx:xx",
"backhaul conntype" : "5GHz",
"backhaul rssi" : "-71",
"backhaul macaddress" : "A0:04:60:xx:xx:xx",
"backhaul phytxrate" : "975",
"backhaul phyrxrate" : "780",
"backhaul parentmac" : "A0:04:60:xx:xx:xx"
I have only one satellite. You have three. If the satellite with WiFi backhaul reports a speed considerably higher than 100, that may be a reason to stick with the WiFi backhaul. WiFi loses a considerable part of the bandwidth to overhead, whereas ethernet does not.
Jsonadam
Jul 25, 2020Tutor
Thanks - sounds good - I have no idea how to do that so for now since it seems to be working with no kids complaining, I will leave it as is unless any other comments sway me to go with wired.
- CrimpOnJul 25, 2020Guru - Experienced User
Jsonadam wrote:Thanks - sounds good - I have no idea how to do that so for now since it seems to be working with no kids complaining, I will leave it as is unless any other comments sway me to go with wired.
Thanks for reminding me of our forum mantra: "If it ain't broke, don't try to fix it." Happy Family is a good indication to leave things as they are.
- FURRYe38Jul 25, 2020Guru - Experienced User
Ive had mine both wireless and wired. I prefer wired for better performance and stability.
