Ninjahedge
Jul 29, 2021Guide
Wired vs Wireless RBR50 V2.
Hi all, I have a weird situation. My wife and I have both been working from home for a while, but this seems to have been starting up relatively recently. I have a Verizon GB router hooked up...
Jul 29, 2021Guru - Experienced User
You'll need to contact the ISP to see wheather or not if there ISP router is needed or if you can connect the Orbi router directly to there interface box.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? If there is a router here, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Ninjahedge
Aug 09, 2021Guide
Furry,
Googling around I found the solution. I am not sure if this is the only thing I will need to do:
It was as simple as turning ON WMM.....
I was under the impression that things like MIMO, Beamforming and other "optimizations" could muck up the works, so I turned them off when I set up the system.
I also turned it off when I was trying to get the bridge to work with what I was able to access (I am not sure I tried to do some of the items that you are mentioning with the modem station, but I did do an IP passthrough from it to the ORBI.
For some reason this worked when the automatic/default bridge setting just refused to connect.
BTW, I turned off the nodes to see if that did it, but I found out that was not the reason.
Summary: Activation of WMM allowed connection to the 801.11ac rather than 801.11a (The suffix never tripped any alarms since I NEVER used that protocol in the past). I searched for 801.11a on Google, got that linked posting and it worked.
Thanks for the information on this, though and I am sorry I did not put the equipment specifics in my original posting!
- FURRYe38Aug 09, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
