mingcyu
Jan 28, 2021Aspirant
Wireless and Gaming - Any hope?
Have RBR50, Firmware V2.7.2.102 and wireless gaming through GeForce Now is unplayable. I mainly play Fortnite with my son (he's on a switch) and I get spotty connection indicator on wireless constant...
Jan 28, 2021Guru - Experienced User
Has a power off for 1 minute then back on been performed since last update?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Wired will always be best for gameing.
Wireless speeds will max out at around 400-500Mpbs, depending upon device design and support. You'll never see anything near 900mpbs on 5ghz AC. You will on a wired connection.
mingcyu
The last thing I tried was setting transmission preamble from automatic(default) to short. Then GeForce Now became super responsive. I will continue to test tomorrow just to make sure it want just because everyone else is asleep
- FURRYe38Jan 29, 2021Guru - Experienced User
Good to hear. Let us know how it turns out.
- mingcyuJan 29, 2021Aspirant
Tested during the day while kids were in school, and understandably performance was poor.
At the moment, have one streaming movie and one kid working on home work it was more manageable. Will keep testing...
The gaming and heavy streaming devices, you'll want to try and wire connect those devices.
