jkra
Nov 14, 2019Aspirant
wireless audio device isn't holding the signal
Hello, i have tried as much as i can to get my como audio wireless radio devices to hold a constant signal but i'm out of ideas. maybe someone here can help. I have 4 como audio (https://www.comoaud...
Nov 14, 2019Guru - Experienced User
Do these devices have there own wifi signal?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- jkraNov 14, 2019Aspirant
Thank you for the response I have the arris surfboard sb8200 it's just a cable router no wifi capabilities. The sat is in that range and I did switch everything to channel 6 after using a device to see whose using what channels around me. 6 was open. I set the Orbi to 40 but it's still dropping.
