PCSP
Apr 24, 2021Guide
Wireless Backhaul 5GHz not working after update firmware v2.7.2.104
Hi Everyone, In past year, I use Orbi Firmware v2.5.1.16 (https://kb.netgear.com/000061838/RBR50-RBS50-Firmware-Version-2-5-1-16). This month, I try to update v2.7.2.104 for security issues (https:/...
Apr 24, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Factory reset both RBR and RBS and setup from scratch.
Walk thru the setup wizard. Be sure to not enable Armor, Circle or Traffic meter. Set time zone and DST to there correct values.
I would had the RBS while in the same room with the RBR to ensure they sync correcty to the RBR. Do this one at a time.
PCSP
Apr 25, 2021Guide
Around 110sqm x 2 (2 floor)
I try to reset factory and set only internet but still same problem not connect 5GHz
I manual downgrade to 2.5.x by login each satellites and upload the old firmware and do the router. I do it when I upgrade to 2.7 too
