zythos
Sep 21, 2019Follower
Wireless Backhaul Channel
I'm really bummed that the wireless backhaul channel is non-configurable. There are two devices that are close to my house that cause interference and renders my wifi network practically unusable wh...
TheDarkSide
Oct 20, 2019Guide
I am having the same issue I believe. I believe the backhaul channels are in the upper 5 GHz range which is causing the interference with my Nakamichi Shockwafe rear speakers which are running in the same channel range. No sure how I can make sure that my rear speakers are attached first and then set my satellites. Have you recieved any guidance from Netgear or anyone else on this?
