zythos
Sep 21, 2019Follower
Wireless Backhaul Channel
I'm really bummed that the wireless backhaul channel is non-configurable. There are two devices that are close to my house that cause interference and renders my wifi network practically unusable wh...
Oct 20, 2019Guru - Experienced User
Can you change the channels of these speakers to use a different channel?
The wireless back haul is mean to be there for any RBS that gets connected via wireless. IT's how Orbi works and NG doesn't seem to respond to any other configurations regarding it. I presume it may come from the chipset Mfr rather then NG and chipset Mfrs implement how the wireless radios work. It's just up to NG to implement and imploy them in to there firmware.
Be if you can get the speakers to change channels if at all possible. Keep them far appart from the Orbi wifi.
TheDarkSide
Oct 20, 2019Guide
Great question and I do not believe so. They have specifically indicated that I should not use the upper 5 GHZ channels since that is where the speakers run at. That said, they seem to indicate I should turn off my router and satellite. Turn on my speakers, allow them to connect and the turn on my router and satellites and then use the "Channel Finder" feature (no sure what this) [channel scanning equivalent] to search for non-congested Wifi frequency to establish the backhaul channel. But I do not believe Orbi has an option to control the backhaul channel.
I guess the main question would be if I do what they indicate and turn on my speakers first and then my router, will this channel location be maintained going forward and be static or will things move as I turn things off and on?
In the end, I wonder if I turn off my satellites when I am watching a good movie will that do it and then there should not be any interference?
- FURRYe38Oct 20, 2019Guru - Experienced User
The upper 5Ghz channel range is from 149 to 161. This is the range that is not user configurable.
So there are some channels that Orbi should use dynamically up there that if other signals are present up there as well, Orbi should avoid and use a different channel. So I presume the speaker mfr is tell you to turn OFF Orbi and let the speaker system get first pick, then onces thats taken, turning ON Orbi should pick something other then what the speakers are using.
- TheDarkSideOct 20, 2019Guide
OK, I will try that. What a pain. I hope that once the speakers have picked and then Orbi has picked it will all stay put and not move. I will try it and get back you. :)
- ekhalilOct 20, 2019Master
TheDarkSide wrote:OK, I will try that. What a pain. I hope that once the speakers have picked and then Orbi has picked it will all stay put and not move. I will try it and get back you. :)
Orbi uses mostly DFS channels for the backhaul so it will be difficult to keep it on the same channel unless you live in an area completely free from radar signals.
You can check the starting channel in your Orbi by enabling telnet in Orbi Router and check the following:
> config get wla_2nd_hidden_channel
You can also change the starting channel, the channel that Orbi will start with after restart as a backhaul channel as follows:
> config set wla_2nd_hidden_channel=108 ==> This will change the backhaul channel to 108 (5530–5550 MHz)
> config commit
