zythos
Sep 21, 2019Follower
Wireless Backhaul Channel
I'm really bummed that the wireless backhaul channel is non-configurable. There are two devices that are close to my house that cause interference and renders my wifi network practically unusable wh...
TheDarkSide
Oct 20, 2019Guide
I am having the same issue I believe. I believe the backhaul channels are in the upper 5 GHz range which is causing the interference with my Nakamichi Shockwafe rear speakers which are running in the same channel range. No sure how I can make sure that my rear speakers are attached first and then set my satellites. Have you recieved any guidance from Netgear or anyone else on this?
schroederboat
Mar 25, 2020Initiate
im having the same issue thats bringing me here... nakamichi sound issues/? anyone find resolution>
