zythos
Sep 21, 2019Follower
Wireless Backhaul Channel
I'm really bummed that the wireless backhaul channel is non-configurable. There are two devices that are close to my house that cause interference and renders my wifi network practically unusable wh...
RonB223
Jun 12, 2020Aspirant
Facing the same issue. Have a Nakamichi Soundwafe 7.1.4 unit with latest updates. The sub is cutting out playing music every few seconds due to interference in the back haul channels used on my Orbi solution. I have model RBR40 from Netgear running firmware version 2.5.1.16. I’ve enabled telnet, entered the commands listed above and rebooted.
Nakamichi refers me to: https://www.helpdesk.nakamichi-usa.com/subwoofer-audio-distortion
This link doesn’t help. When I reboot my Orbi solution with audio playing, my routers keep picking a conflicting channel with the sub. Getting really annoyed.
I’ve thought about returning the Nakamichi unit but doing research Sony and a few other wireless sub solutions also can have interference in this upper frequency range.
I must have a solid way to disable the higher frequencies for backhaul or to pin it to a particular channel so I can experiment with the best one that interferes the least.
ekhalil
Jun 13, 2020Master
- One way to minimize the backhaul frequency broadcast is to disable Daisy Chain, so that only the Router node (the RBR40) broadcasts the wireless backhaul frequency and not the Satellites.
- When restarting the Orbi Router, make sure that the soundbar is on and close to the router (RBR40) so that the router will choose another frequency than the frequency used by the soundbar.
- Please make a wireless scan (using a computer or phone) and see which channels are being used by Orbi.
