jal69
Apr 05, 2020Aspirant
Wireless Backhaul Status
I have an RBK50 (1x RBR50; 1x RBS50). Firmware 2.5.1.8. Running Windows 10. I have a Spectrum Internet modem feeding the RBR50.
I've seen posts where people have commented on what their backhaul status is (good, poor, etc.). I have tried to find mine but cannot find anywhere that tells me what it is. The App doesn't seem to tell me anything other than there is one satellite and there is a dotted line between it and the Router. [Not sure what the dotted line means either (wireless vs wired?).] When I access the router through the browser, I see the satellite on "attached devices" but there is no IP listed, no connection type, no connected Orbi listed and the backhaul status says 'disconnected'.
I have rebooted everything, sync'd everything, moved the RBS50 closer to the RBR50 but it never changes from "disconnected".
Picture is the screenshot from the browser.
Any and all help is appreciated.
Is the Orbi system operating in Router or AP mode?
Be sure FW is the same version on the RBS as the RBR.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQYes, the dotted line means a wireless connection, solid line means the RBS is ethernet connected to the RBR.
- jal69Aspirant
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too? Model E31T2V1 - did not list manufacturer; maybe Ubee? It is a DOCSIS 3.1 Modem.
Is the Orbi system operating in Router or AP mode? Router
Be sure FW is the same version on the RBS as the RBR. - They are same
What is the size of your home? Sq Ft? ~3000; router and sat on same floor at opposite ends.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerDistance is around 30 feet. I've also moved it much closer but got the same reading -- disconnected -- in the browser.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Currenly 2.4GHz on 11; was on auto previously. 5GHz channel is on 48.
Any Wifi Neighbors near by? If so, how many? There are other wireless around but much lower power levels and none on same channels as me -- as least that show up on WIFI Analyzer.Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings Already are; only fast roaming is disabled.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Fast roam is disabled; Dasiy chain is enabled (I will check that in a bit once my wife is finished her zoom session). Preamble is seet to "Auto" fro both 2.4 and 5G. Enable 20/40 MHz coexistence is checked. IPv6 is disabled.
https://www.youtube.com/watch?v=ePZSc7vnRlQYes, i updated fw awhile back. In Jan switch ISPs and did a factory reset to start fresh for router mode needed for Spectrum Modem.
Yes, the dotted line means a wireless connection, solid line means the RBS is ethernet connected to the RBR. Thanks
Try disabling Diasy chain. You may need to reboot or power cycle the RBS. Power OFF the one RBS that is appearing in the status page. I would power off the RBS that isn't appearing on the RBRs web page, bring it to the same room as the RBR and power it on and let it sync and check the status.
