jal69
Apr 05, 2020Aspirant
Wireless Backhaul Status
I have an RBK50 (1x RBR50; 1x RBS50). Firmware 2.5.1.8. Running Windows 10. I have a Spectrum Internet modem feeding the RBR50. I've seen posts where people have commented on what their back...
jal69
FURRYe38 wrote:Try disabling Diasy chain. You may need to reboot or power cycle the RBS. Power OFF the one RBS that is appearing in the status page. I would power off the RBS that isn't appearing on the RBRs web page, bring it to the same room as the RBR and power it on and let it sync and check the status.
I did that about 2 hours ago the only difference was that Dasiy Chaining is enabled. Thought that wouldn't have an impact since I only have a router and one sat. RBS was literally across the room from the RBR. Same status - disconnected. I will disable Daisy Chaining and try it again in about 15 mins so I don't risk disturbing wifi.
jal69
Oh, and the Orbi app says there is one satellite but the browser (routerlogin.com) says there are no satellites.
